Kahuna
THE MORE YOU PLAY WITH IT, THE BIGGER IT GETS
- Joined
- Aug 31, 2014
- Posts
- 870
- Reaction score
- 794
Hi,
Can I get a little help from the experts on this one? I am looking to install a bulgin switch for a pair of bumper mounted spots on the Mrs's Jeep but I missed electronics 101 growing up and now need special ed.
I want to rig the spots to be triggered by the high beams, only when the latch switch is engaged. I would like for the LED on the switch to be on when the ignition is on and the switch is on (latched), whether the high beams are on or not.
So operation would be like this:
a. Ignition off, Switch any, High beam any: LED OFF
b. Ignition on, Switch off, High beam any: LED OFF
c. Ignition on, Switch on, High beam off: LED ON
d. Ignition on, Switch on, High beam on: LED ON
I have been taking the 1&4 DC connection from the high beam circuit as showing the diagrams below and the lights function as I want, but the switch LED is off when the switch is closed but the high beam is off (c on my list).
I hope i have been clear. Any help would be much appreciated to get the switch working as per a-d above.
Thanks,
K
Thanks,
K
