Automatic Tailgate lock
TheWolf
Spokane, Washington
I felt guilty about not posting any pics. Here is one of the new cable wiring, one showing where I added plastic wire loom where it comes out of the frame, and a final one showing where it goes into the existing grommet that is located just below the fuse panel on the 2014. I ended up using hot glue on the inside of the grommet to make sure it does not pull out.
Lxg44
I have a tool box with power actuators for the locks ( one on each side). If I tie these into the same connection as the tailgate lock do u think it will overload the circuit?
MTF
MTF
Celebration, Florida
Now that's a good question! Hummmmmm
I wish I had an answer for you.
So far nobody has had an issue with the Screw (4dr.) and the tailgate lock.
Try hooking up one at a time, just to be safe.
It's not like these are high amp devices.
Lxg44
Not familiar with relay wiring. Could you provide a relay spec and wiring example? I appreciate any help you could provide. I'm a very experienced DIYer but want to make sure I get it right the first time.
MTF
MTF
Somewhere in the thread there is a wiring diagram of the relay you would need.
I'm on my phone now if you can't find I'll put something up tonight.
aka grumpy car stereo guy
if these are a two wire actuator, you will need 2 relays. one for unlock and one for lock.
relay 1
85 -constant pwer
86 - unlock from factory wiring (- trigger)
87 - constant power
87a - ground
30 - goes to aftermarket actuator unlock wire
relay 2
85 - constant power
86 - lock wire from vehicle (- trigger)
87 - constant power
87a - ground
30 - goes to aftermarket actuator lock wire
SPYC-2X
McKinney, TX
Just installed mine tonight. Because of this thread, I was able to locate the correct wires and get it right the first time. I used the grommet just below the kick panel on the front passenger side and then tidied up the wiring along the frame rail.
I will take the OP's advice and add some foam around the actuator to dampen the vibration caused when closing the tailgate. Would be great if Pop & Lock would include it with their product. Minor oversight in an otherwise complete kit. Very happy with the results!
SVT Guy
Houston, Tx
No diagram needes. Front pass door. Here ya go.
SPYC-2X
McKinney, TX
This has been stated before but as a reminder, there are two violet wires with gray stripes. They are slightly different gauges - you want the one that is the same gauge as the gray wire with the brown stripe. This is the bigger of the two by my account.
