aftermarket stereo builds
Devilsfan72
Jersey
No pics, but this is what I'm running
Audison bit one, jl audison stealth box, audison voce 5.1k, audison av k6, audison av x5 , audison drc, and as soon as I can source one an audison bit play
LFtrip
Glendale, CA
One of ^this guys^ systems modified to fit my budget. JL cleansweep and summing device, JL 700W/5 ch amp, JL 10TW3 in ^this guys^ box, and el cheapo kicker 6x8s in the doors (to eventually be replaced with JL C3's)
How do you mount everything behind the rear seat without drilling through the cab? The guys at Al and Eds in Los Angeles said its not possible yet I see it here.
Also, Noah do you have a right up I could give these guys to install the cleansweep and summing device? They seem lost when I ask them about it.
aka grumpy car stereo guy
you drill into the brace where there is 2 layers of metal. that way you dont drill through the cab
WHYUMAD
New Orleans, LA
I'm building a halfwall in my supercab. Here's following system set up:
- Mechman 370 Amp Alternator (Same alternator as DC Powers, but $200 cheaper. both use the same exact alternator for the 370 amp)
- XS Power 6500 (Primary Battery)
- (2) XS Power D3100 (Secondary Batteries)
- Sundown Audio NS-1v2 6500 Watt Mono Amp
- (4) Sundown Audio SA-12
- Alpine X009U 9" Head Unit
- Still deciding on highs setup, but doing one set of components up front, 6x8s rear door, & 4 6x9s in rear deck.
If you're getting a sound processor, get the Mosconi. The Rockford 360 & JL Cleansweep have too much noise, just like the AudioControl processors. JBL MS-8 is mehhh...Mosconi is the best one I've dealt with so far.
---------- Post added at 02:36 AM ---------- Previous post was at 02:35 AM ----------
Also, the best sound deadening material to use is Damplifier Pro..do the roof, rear cab wall, & door panels. Use some fillers for any holes/openings in the cab as well.
LFtrip
Glendale, CA
Is it just me or does the mosconi look easier to install than the cleansweep? Would I only have to pull the RCA ins off my amp, plug them into the mosconi then more RCA to my amp?
