Aftermarket DVD/Navigation System
cayenne
Windsor, CO
I think the Alpine is definitely the better solution. This should work well as long as you don't have the Factory NAV. I don't believe anyone has come out with a solution to replace the Factory NAV.
Stang
To clarify my other post, bluetooth issue was with crappy S4 software not Kenwood /Maestro. That is a sick setup integrating everything nicely into Sync.
Curious, does the pioneer give you OBDII inputs like the Kenwood? It will show you tire pressures, diagnose check engine codes, etc. They have climate control integrated on other Fords but not F150 yet.
Sent via Tapatalk 4 for Android
Dusty Bottoms
Ft. Sill, OK
anything prior to 2013 shouldnt be a problem. pioneer and alpine make great nav units. and there is a dash kit available for those year trucks as well.
Has anything come out yet for those trucks that have built in Navigation where the climate controls are controlled through the Nav unit? I have a 2012 with factory Nav and the climate controls are controlled via the Nav screen. No one seems to know if I can upgrade or not.
stuntmonkey
Same thoughts here!! I made a new thread about the alpine restyle. For the FD2 version it controls climate through the unit but couldn't find that in the fd1 which should be for our trucks.
