Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > GEN 1 (2010-2014) Ford SVT Raptor Forums > Ford Raptor Audio/Video/Electronics Forum [GEN 1]
2012 dsp suggestions for stereo upgrade
This is a discussion on 2012 dsp suggestions for stereo upgrade within the Ford Raptor Audio/Video/Electronics Forum [GEN 1] forums, part of the GEN 1 (2010-2014) Ford SVT Raptor Forums category!
Old 06-30-2018, 09:59 AM   #1 (permalink)
Junior Member
Default 2012 dsp suggestions for stereo upgrade
I recently upgraded the stereo in my 2012 supercrew.
I decided on Diamond Audio again for this build where I have used their stuff on 2 previous vehicles. FJ cruiser and Subaru. Both sounded excellent. For the raptor I chose.
Diamond Audio
H65s speakers for front and rear
2 12Ē shallow mount diamond subs
HX1200.5 amp
Audio control lc7
Still the music is lacking a full sound to me. sounds like itís missing certain frequencies. Any suggestions? Do I need another dsp or add in an equalizer. Or is there a way to bypass the factory amp that may be the culprit.
Last edited by Tomilton; 06-30-2018 at 10:01 AM. Reason: Picture shows upside down, canít figured out how to fix it
Tomilton is offline   Reply With Quote
Old 07-04-2018, 01:18 PM   #2 (permalink)
Junior Member
Are you using the factory HU?
Kevin K.
Kostiuk is offline   Reply With Quote
Old 07-04-2018, 05:32 PM   #3 (permalink)
AZEngineer's Avatar
I used a JL Audio Cleansweep and Signal Summing device in mine. Apparently the factory Sony unit varies the EQ through the volume range. With the JL unit you play a special calibration CD and the DSP in the JL Unit make the signal flat again. JL Audio has since replace the two units with an integrated one. If doing again I would buy the 6 channel version so I could get front rear fade.
AZEngineer is offline   Reply With Quote
Old 07-09-2018, 01:03 PM   #4 (permalink)
Junior Member
I am using the factory head unit. I have been looking at different dsp devices and keep seeing post about people using different products and still having trouble getting a clean or flat signal to the amp. I have looked into pac audio unit because it goes in before the factory amp, but my buddy who owns a car audio store says pac is junk
Old 07-09-2018, 01:28 PM   #5 (permalink)
The Car Stereo Company's Avatar
aka nosbusa
i am partial to the mosconi 6to8. we do tuning for sq competitions and the mosconi is our processor of choice due to the adjustments available.
its not how fast you can go......its how fast can you get to fast......
The Car Stereo Company is offline   Reply With Quote
Old 07-12-2018, 11:10 PM   #6 (permalink)
Junior Member
I sent my factory nav unit off and had it reprogrammed to put out a signal that could be fed directly into an aftermarket amp. It sounded like shit. I bit the bullet and replaced the factory HU with an aftermarket. I never did try a sound processor. I guess they work pretty well but I am a skeptic after hearing the crap coming out of the factory HU I just don't see how you can replace whats missing and have it sound as good as an aftermarket unit.
Kevin K.
Old 07-13-2018, 09:10 AM   #7 (permalink)
aka nosbusa
Kevin K.
i am in the springs
DIY stereo upgrade for under $500.00 Guy Ford Raptor Audio/Video/Electronics Forum [GEN 2] 261 06-24-2018 11:03 PM
Stereo upgrade Sutton_Gentry Ford SVT Raptor General Discussions [GEN 1] 3 04-14-2018 08:54 PM
2018 B&O stereo upgrade BDF Ford Raptor Audio/Video/Electronics Forum [GEN 2] 27 03-13-2018 08:55 PM
GEN 2 Stereo Upgrade SOAKINRED Ford Raptor Audio/Video/Electronics Forum [GEN 2] 16 03-08-2018 09:04 AM
