Any of you guys tow a trailer?
OregonSVT
Thanks. Yeah, this is my first dual-axle trailer. I hauled an 18" jet-boat years ago, but it was much lighter and only had a single axle. I hauled it with a Suburban and didn't have to level it really. Never had issues with it.
This looks much more complicated than I thought. I may just have the RV dealer set it up for me.
I agree with what was posted above. My guess is that if you pull full of water you will easily exceed 800lbs on the tongue with a trailer of that size. My 19' Lance is around 550 lbs on the tongue and 3500lbs on the single axle.
My recommendation is to have the RS dealer install the weight distribution, but then take it to a truck scale on the side of the road with the trailer and truck loaded as if you were going camping and adjust accordingly. From my experience, the dealers suck at setting these things up. I use a Reese weight distribution with my trailer and it works well. If you have a similar setup, make sure the sealer does torque the bolts that angle the ball too tight where you can't adjust them. The don't need to be torqued to 450lbs+, or if you want them that way, take it back after you adjust.
seapong
Folsom, CA
22ft centurion avalanche 3600lbs dry weight + trailer, ballast bags we dont drain sometimes, and gas comes to about 5000-5500lbs, no problems.
i use a tri ball hitch (no drop)
Sinraptor
Greer, South Carolina
Just bought a 2018 Flagstaff Micro Lite 21FBRS Camper. Towed it home couple weeks ago, did great. Taking it on its first trip next week to Myrtle Beach. Will give feedback of how it towed.
racerjb
Xventure XV-2 tows perfect behind raptor
BMONTES
San Fernando Valley (Los Angeles)
Stopping off in Bishop for lunch at Schat’s on the way to Mammoth Lakes this past July. Rented a 24’ Jayco, probably around 6,000lbs loaded with the family. SFV to Mammoth got about 10.9MPG. Hottest transmission got was about 244 for about 10min on the steep climb.
