BramageDained
- Joined
- Aug 4, 2012
- Posts
- 761
- Reaction score
- 449
SCCA RallyCross//10MAY//Cambridge, MN
Land O' Lakes Region RallyCross page
Registration Link
Cost:
$15 for weekend SCCA Membership
$45 for the event
$10 late fee for late registration day of.
RULES:
All competitors and spectators must sign the official SCCA Waiver of Liability.
All minors present must have a minor waiver printed in color and filled out.
All competitors MUST work the course as a condition of event entry.
All competitors must have an FRS Radio, radios cannot be shared between competitors.
All competitors must have a Snell/M2000 or newer helmet. Loaner helmets are available but the quantity is limited.
Passengers will be allowed if waivered and wearing an approved helmet.
Passengers are not allowed to hold items during the run including cameras
See official rules here: Rules.pdf
Cars will be checked for the following items, please make sure your car passes all the listed items before the event.
·All loose items (including floor mats) removed from inside and outside the car (including the trunk and storage areas)
·Snap‐on hub caps and other detachable accessories (e.g. fender skirts, trim rings) removed
·Convertible, targa or t‐top vehicles must have their factory hard top panels securely in place
·Lug nuts tight, correctly installed, and none missing
·Tires in good condition and have adequate pressure (no cords or belts showing, no cracks, etc.)
·Seat belt(s) present and properly attached
·Positive throttle return
·No excessive leaks (engine running)
·No “spinner knobs”
·Brakes in proper working order
·Wheel bearings, steering and suspension in good working order
·Battery tightly secured, positive terminal insulated
·Helmet rated Snell SA2000/M2000 (or newer), BS 6658‐85 type AF/R or SFI 31.1
·Each Driver has a FRS Radio (we usually use channel 8-0) I have 2 spares
Classes are Stock, Prepared, and Modified and then each class is divided up into FWD, RWD, and AWD. See official rules for car classing.
Schedule:
8:00 – 9:00: Registration Open
8:00 – 9:30: Tech Inspection Open
9:30: Drivers Meeting
10:00 – 10:45: Set 1
10:50 – 11:35: Set 2
11:40 – 12:25: Set 3
12:25 – 1:25: Lunch break while we reconfigure the course
1:25 – 2:10: Set 4
2:15 – 3:00: Set 5
3:05 – 3:50: Set 6
Remember to drive with respect for our land owner and his neighbors on the way in and out of the venue! If not, you may be banned from future events.
Isanti County Fairgrounds
Cambridge, MN
Cambridge is about 40 minutes north of Minneapolis on MN65.
I'll be out there running my truck. This is a new site for RallyX, so I can't comment about it.
There will be a portajohn, bring your own lunch/soda.
I meant to post this sooner, but, was waiting for the report on the site being checked out.
Registration Link
Cost:
$45 for the event
RULES:
·No “spinner knobs”
Schedule:
1:25 – 2:10: Set 4
2:15 – 3:00: Set 5
3:05 – 3:50: Set 6
Cambridge, MN
