Radio programming information
Slacker
Alexandria, VA
So I want to start a thread for 2 reasons: First, I can't find the info anywhere else. Second, I know I can not be the only guy that is lost...
I see freqs posted for various rides. Some radios can be set up from the radio, others require programming through a computer. What I am hoping to do is put together a definitive list and import files for major radio brands. One problem: I don't have a clue what any of it means. So here is the CSV file I put together for my Kenwood TM-V71a.
https://www.dropbox.com/s/fqd356ktnlj2ya2/FRF Freqs.csv
I really need someone to take a look at it and see if it is jacked up or not, and see if I got all of the common freqs. If someone can post an ICOM, Yaesu, etc export just so I can get the file format I will update his post with downloads for every brand I can, I just need a sample export to know what format is required. I will also post a text of the freqs for those that cannot use the import files.
I really am lost with this radio so any help is appreciated. I will share what I get from you so it can help others.
All The Way
Lockport, NY
Slacker
Slacker
Alexandria, VA
Every radio is gonna be different. I have 3 Yaesu rigs and they all use different formats.
Well that isn't going to make things easy.. Thanks for the samples though.
With your radio more then likely you will have to modify it to transmit on the frequencies used for runs.
I got the MARS/CAP mod when I bought it.
Slacker
Slacker
Alexandria, VA
Does anyone know if you can add a receive freq without adding a transmit freq? This would be for things like police bands where I want to be able to listen but not accidentally transmit.
Big Blue
Administrator
Staff member
Admin
USA
This may not help the OP, but all Radios sold by GLRE (Handhelds and Built-ins) are already pre-programmed with all of the channels needed for any of the various Raptor Runs. :cool:
All The Way
Lockport, NY
Just put the receive frequency in as simplex. Since most PD and Fire use PL tones you wont be able to interferer with them. Someone with a scanner will hear you though....
