The 2018 SnoBall 1/12-15/2018
SeXualAVENGER
Peoria, IL
I'll need some new rear ambers. Not sure how I want to do it. I really don't want to drill into the ARE cap.
Sent from my SCH-I545 using Tapatalk
Check out some 3m vhb tape. That stuff is super strong as long as you prep the surfaces well and have the right tape for the job.
rkneeshaw
Northern Michigan
My ambers are ready
And I'm set for my HAM exam in about 2-3 weeks. My radio arrived the other day, I went with a handheld unit because I'm not ready for a permanent install, hopefully it still works well. Its a high power 8w Baufang.
McGrath4u
Can you utilize the third break light mounts in the cap to mount some lights? Swap it out quickly at the hotel when you get there and when you leave?
Ditchplains1
Trescott, ME
YukonJoe,
Alternative Offroad sells a suction cup kit for mounting LED whips. I've seen the set up and the suction cups hold amazingly well...
Of course with sub zero temperatures I can't be sure if they'd still be pliable enough to stick.
Make a flat mount and use 3M automotive double sided trim tape? Easy enough to remove later, and no worries about ice crystals breaking the adhesion...
Eddie
Yukon Joe
Russellville, AR
So @Yukon Joe which one of the bambinos is going to be your co-driver???
@RaptorWifey will be my copilot of course! She may not pump the gas, or clean the windows, but she is the best damn navigator I know. :driver:
I think it's because she likes to tell me where to go.... lol
:wizsmile:
93,171
56,440
jumpcutter
