Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > GEN 1 (2010-2014) Ford SVT Raptor Forums > Ford Raptor Exterior Modifications Forum [GEN 1]
WSI Hidden Winch Mount Installation
This is a discussion on WSI Hidden Winch Mount Installation within the Ford Raptor Exterior Modifications Forum [GEN 1] forums, part of the GEN 1 (2010-2014) Ford SVT Raptor Forums category!
Originally Posted by JROCKZ24 I already have the SDHQ Hidden Winch Mount installed with the Recon. Do I have to ...
Like Tree3Likes
Old 04-19-2014, 04:35 PM   #21 (permalink)
OrangeAddict's Avatar
Originally Posted by JROCKZ24 View Post
I already have the SDHQ Hidden Winch Mount installed with the Recon. Do I have to take the bumper off to get the WSI Mount for the Whelen's in there? I tried to work it in there to no avail so far. Can one of you guys help me out? I couldn't find any pics on line of the mount setup, so I'm not exactly sure what it bolts to. Looks like there are stock hole available that are the right width, but the sdhq mount covers them up, so I'm guessing I have to drill throught the sdhq mount.
here you go. I have not been able to get the is write up done.
guess I have a reason now.
No, no, no. There's no such thing as cheap and cheerful. It's cheap and nasty & expensive and cheerful. - Jeremy Clarkson
Badges: Havoc in the Hills 2013 - Rock, Mudd, GLRE Initiation | SnowBall 2014 - Delta, Knight Raptor, Aqua Raptor/Water Crossing, Snow
OrangeAddict is online now   Reply With Quote
Old 04-19-2014, 04:41 PM   #22 (permalink)
JROCKZ24's Avatar
I obviously have the wrong mount then, because there is no way in hell it's going in there the way you have yours. Thanks for the quick reply. I'll get with jimmy at wsi and try to get the right mount.
It pisses me off because this email interaction took place before shipment.
JROCKZ24 is offline   Reply With Quote
Old 04-19-2014, 04:47 PM   #23 (permalink)
Yeah that may have a problem. Even if you get it behind the fair lead it looks like there will be a problem.
Old 04-19-2014, 04:49 PM   #24 (permalink)
JROCKZ24's Avatar
Yeah, the housing behind the fair lead is wider than the fair lead by at least an inch on both sides[IMG]http://img.tapatalk.com/d/
14/04/20/6ymejajy.jpg[/IMG]
Old 04-19-2014, 04:57 PM   #25 (permalink)
Huck's Avatar
He told me last week his light mount won't work with the SDHQ mount. I'll get the email
Icom F5021,RPG Stg 4+ Fox 3.0 coilovers, RPG Tie-rods (modified to camburg hardware), RPG PS reservoir, Camburg 1.25" UCA's , Raptor -Retro fit '13 HIDS, Line-x preminum, Bluewater LED bed lights, Ipad mini navigation. Bubba rope. Rollx, Recon 10.5k winch synth rope, factor 55, SVC Custom acuated tower. Visions 30" xmitter extreme, 35" toyo MT, visionx 6550 spot.
Huck is offline   Reply With Quote
Old 04-19-2014, 05:01 PM   #26 (permalink)
JROCKZ24's Avatar
I think I can just drill into I the frame and mount it to there. The only problem is the light not fitting into the hole.
Old 04-19-2014, 05:12 PM   #27 (permalink)
Wilson's Avatar
Just by looking at it I'd say it looks like it's suppose to be behind that front pice.
2018 calendar link >http://www.fordraptorforum.com/f16/2...ictures-54101/
Jeff Ethanol I use it
2012 #3105 Diablosport tune aFe stage 2 SW Headers Xpipe true duel S-type muffler 361rwhp
Wilson is offline   Reply With Quote
Old 04-20-2014, 09:30 AM   #28 (permalink)
Yukon Joe's Avatar
Give me a call. I might be able to help. I sent you a PM.
The SDHQ mount should be able to accommodate lights. Unless it's an older mount.
Also, by the photos, it looks like the Whelen lights will fit, but will be snug.
Yukon Joe
www.RUNRAPTORRUN.com
2012 SCREW | NIGHT RAPTOR Revolution Wrap | RPG Stage 4+, Black Tie-rods, Prerunner 1.0 UCA, Steering Res | AMB LED Light Kit | Raptor Retrofit HIDs w/ Amber Ring | Hefty Fabworks Skid Plates | ADD ABS Guard | Recon 10500lb Winch w/ Factor55 | Whelen LEDs | WSI FE Mount | Extang Solidfold | Weathertech Liners | PDP Flaps | TYT9000VHF Radio |
I love Raptorwifey
Yukon Joe is offline   Reply With Quote
Old 04-20-2014, 12:10 PM   #29 (permalink)
Huck's Avatar
SDHQ had a cut out for lights, but they are vertical, designed for visionx lights per their website
Tags
recon, warn, whelen, winch mount, wsi
SDHQ Hidden Winch Mount - Canada jeeper Garage Sale 5 08-18-2013 07:00 PM
hidden winch mount installed uaq69 Ford Raptor Exterior Modifications Forum [GEN 1] 9 10-20-2012 11:54 PM
Hidden winch mount with KC Lightbar avnmaintman Ford Raptor Exterior Modifications Forum [GEN 1] 9 09-17-2012 10:41 PM
hidden winch mount uaq69 Off-Roading Your Raptor 0 02-08-2012 07:41 PM
