Sprayed Tailgate Help
I removed the tailgate step and plastic bed liner from the tailgate. I want to get the tailgate sprayed to match the factory sprayed in liner. Any recommendations on which spray in liner (Line-X, Rhino, etc) that matches the factory liner the best?
BigBlock
Whatever you decide to get, make sure it's a high pressure application. Durability wise, LINE-X will be closer to the factory bedliner than Rhino. Actually, LINE-X is more durable than the factory bedliner.
