Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > GEN 1 (2010-2014) Ford SVT Raptor Forums > Ford Raptor Exterior Modifications Forum [GEN 1]
Rear 2in flare mod for stock bedside
This is a discussion on Rear 2in flare mod for stock bedside within the Ford Raptor Exterior Modifications Forum [GEN 1] forums, part of the GEN 1 (2010-2014) Ford SVT Raptor Forums category!
Been waiting for a chance to try out a idea i have had for a while. Making cut out flares ...
Like Tree89Likes
Old 02-16-2014, 11:10 AM   #1 (permalink)
khcdave's Avatar
Default Rear 2in flare mod for stock bedside
Been waiting for a chance to try out a idea i have had for a while. Making cut out flares for the rear to match front fiberglass fenders. These are stock rear flares with 2 inches cut out. The bed gets modified but does not need to be repainted and the flare snaps back in to the factory holes then bolted around the inside. The bed side can also be flared slightly at the same time. The flares in the pics are not finished but it shows how it looks with a stock bedside thats been modified. We are working on the flare making process.
khcdave is offline   Reply With Quote
Old 02-16-2014, 11:16 AM   #2 (permalink)
justvettn's Avatar
What exactly was done? If I understand right you cut the metal bedsides 2 inches and somehow modified the factory flares?
justvettn is offline   Reply With Quote
Old 02-16-2014, 11:19 AM   #3 (permalink)
Macman's Avatar
If I am understanding properly you modify bedsides and bolt in aftermarket flares into the stock holes to give 2 more inches of clearance to match front aftermarket glass? Cool idea especially if you don't have to repaint!
2012 SVT Ford Raptor Screw - Blue Flame Metallic
2013+ FX4 HIDs|RPG Stage II|Undercover Flex|40" LED Bar|Method NVs|Mid Perch|
1969/77 Ford Bronco
2002 Honda s2000
Macman is offline   Reply With Quote
Old 02-16-2014, 11:21 AM   #4 (permalink)
justvettn's Avatar
He says stock rear flares with 2 inches cut out.
Old 02-16-2014, 11:51 AM   #5 (permalink)
khcdave's Avatar
Stock flares are modified by cutting 2 in out of them and they are welded back together. The bed gets cut all the way around the pinch weld, sliced every 4 inches and bent back to create a new lip 2 inches higher all the way around. The stock support is completely cut out just like when u do complete bed sides. The modified flare then goes back in just like factory. More pics as I perfect the process. The pics show both the bedside modified and the flare in the process of being put back together. I am searching to see if anyone will make the flares for us but reusing the stock flares is still an option. This just shows what it will look like.
Dave Venti
Old 02-16-2014, 04:35 PM   #6 (permalink)
Dan06's Avatar
Do the bedsides need to be pulled for the mod or can it be done while they're still on the truck?
Dan06 is offline   Reply With Quote
Old 02-16-2014, 04:40 PM   #7 (permalink)
justvettn's Avatar
Still on the truck. You would not want to remove just to do this simple mode
Old 02-16-2014, 05:05 PM   #8 (permalink)
khcdave's Avatar
Yup bedsides stay on the truck. I will post the pics of the cut and bend procedure soon. It's very simple.
Dave Venti
Old 02-16-2014, 05:16 PM   #9 (permalink)
justvettn's Avatar
When you say weld the flares, I assume you mean plastic welding?
Old 02-16-2014, 07:25 PM   #10 (permalink)
khcdave's Avatar
Yes. Plastic welding the flares. This is to build the molds
Dave Venti
justvettn likes this.
WTB stock passenger rear fender flare CSmith Want to Buy 0 02-11-2014 06:04 PM
right rear fender flare grey SVTscott Want to Buy 2 01-08-2014 08:33 PM
WTB stock rear passenger side fender flare fjcoop Want to Buy 3 01-06-2014 12:54 PM
2013 Rear Fender Flare(S) TPMS Sensor Biggest Want to Buy 0 10-10-2013 07:01 AM
WTB: Right rear fender flare OregonSVT Want to Buy 1 06-27-2013 05:09 PM
