RaptorScrew
I purchased this setup from a member here on the forum and love the overall setup! No questions!
The Support plates sit on the inside of the fender and are not accessible from the inside of the bed. @Kmandoske and I bolted on raw steel shims to the rack. The shims go UNDER the Retrax One. There are two bolts holding the Retrax to the Shim to the Bed Rail.
There are there upside down bolts holding the rack supports onto the shims. The whole setup was used to get the rack back to Rochester, MN from Keith's place.
I'm looking for something that isn't "Thrown together" and doesn't look cobbled.
I've touched base with Jimmy @WSI to get his thoughts. I'm wanting definitely a more professional look to it. I'd have to weld a new shim to the bottom of the rack and then have than tuck under the Retrax (which I'm trying to keep also).
Any thoughts would be greatly appreciated.
Rick
Rick
