Glass Fenders, really worth it??
Dan06
The Dark Side of The Moon
I personally believe they should come with them from Ford. I am currently running stock wheel/tires, mid perch, and glass fenders. Still stuff the tires up far enough on hard landings to rub the upper bracing. Fixing to install some inner fenders, however I'm afraid I'll trash them without going to top perch or 3.0s.
Rookie
Fort Wayne, IN
They're worth it. Especially if running 37s. Personally I'd go with fronts and rears to make it look uniform. Don't care for the fronts and no rears.
Raptizzle
FYT
Southern CA
They are only worth it if you run 37's and plan to stuff the tires on the regular. The fit and finish will never be as good as factory regardless what aftermarket glass you choose.
Raptor Addict is coming out with a new glass setup for the front and rears so I'd recommend waiting to see what he's releasing before making your decision.
IRONMAN
Well-Known Member
MICHIGAN
This ^^^^
Allied Offroad
Kansas City
But for the rears wouldn't you have to cut up the bed of the truck?
You have to drill out all the spot welds out and have to trim slightly around the taillights. You also have to do some trimming inside the rear fender wells . If you do clean work you'll hardly notice it when your done. Most people don't realize we're running rear glass on our OD green rig.
To answer your question, no you don't have to "cut up the bed" but you have to do some cutting on the bed.
WSI does fiberglass installs on Ford Raptors.
WilsonRaptor
WilsonRaptor
Well-Known Member
A shit hole in Southwest Texas
How much does a full fiberglass install through y'all usually cost?
