Front Fender Removal?!
Wrong Way
Whats up with the foam you had to cut out(purpose)? How many bolts and fasteners holding that fender on? Good call on that undercoating looks great.
gotSVT
gotSVT
SoIL
I think there are only 7 or 8 bolts. The foam is "filler" so dirt doesn't enter the cab side of the door jam. Open your door and look in there - you'll see it.
gotSVT
gotSVT
SoIL
Almost there...
---------- Post added at 09:53 AM ---------- Previous post was at 09:47 AM ----------
Whats the weight difference between stock and the after market fenders?
The glass fenders with LineX weigh about the same as the stock ones.
Aaron
Meme Corps Commandant
WA
GotSVT those are badass! I love the linex on the flares too.
BO that right there is why I wish I had a white truck sometimes
...you can get away with running the glass unpainted for awhile haha
gotSVT
gotSVT
SoIL
Word of advise for anyone doing paint & LineX on the fenders. Do the LineX first. I had to repaint the fenders after the LineX guy was done with them.
gotSVT
gotSVT
SoIL
Bo, check the clearance where the red circle is. The glass kind of sticks out toward the hood just inside the opening. I almost missed it and it looks like you might have from the picture too. It is easy to miss.
BOJANGLES
Chihuahuan Desert (EPTX)
Mine is close, but the hood clears just fine. Raptorguy21 and I adjusted, mounted, re-adjusted, mounted, re-adjusted, mounted over and over again on both sides to get them as perfect as we could. Made the process take a lot longer but it was worth it because the gaps came out really clean and tight.
BOJANGLES
I know you guys with other colors all like to deny it, but there are so many advantages for white paint on desert Raptors I don't even know where to begin listing them all.
:burnout:
