Cutting into rear bumper! Is it tough?
andreb
City by the Bay
Before I drill the first hole just curious if anyone and drilled, cut or otherwise created holes in the bumpers. The chromed bumpers on my old '95 Ranger were tough/hard. I'm installing some Rigid flush-mount LED floods and connecting them to the back up lights with a Starkey harness. My plan was to drill and use a cut-off wheel but I have a jigsaw, sawz-all and plasma cutter also. Considering starting with a hole saw and then squaring it out. Any input is appreciated.
Sano Dano
Encinitas, CA
Before I drill the first hole just curios if anyone and drilled, cut or otherwise created holes in the bumpers. The chromed bumpers on my old '95 Ranger were tough/hard. I'm installing some Rigid flush-mount LED floods and connecting them to the back up lights with a Starkey harness. My plan was to drill and use a cut-off wheel but I have a jigsaw, sawz-all and plasma cutter also. Considering starting with a hole saw and then squaring it out. Any input is appreciated.
Pretty easy to do.......Bumper is pretty thin....I used a metal cutting blade on a 4" hand grinder.
CoronaRaptor
CANADA
I have the same rigids, they come with a paper cut out to help you. Don't use a hole saw, drill in all four corners and use a cut off wheel or similar. As mentioned, TAKE YOUR TIME!
aka grumpy car stereo guy
an air/body saw is the best thing to use. i use blades with 24 teeth per inch. think of it as a sawzall but smaller and much easier to control.
