Cheap Bed Ring MOD
HAP
HAP
NE NC
Yeah, I just used the de-burr wheel on my bench grinder and just buffed them down enough...
R,
HAP
Yukon Joe
Russellville, AR
@HAP - I like the chain in the back of the truck. Looks like a nice way to be able to strap in gear and other things.
what's the plastic cover for? To keep it from hitting the wheel wells?
HAP
HAP
NE NC
Yeah, that's just a piece of 1" vinyl tube over the SS chain to minimize noise and wear to the Linex. Also, not visible is a rubber bungee stretched from one chain to the other under the tool box to keep the chains under tension, also to minimize any movement/noise. It simply provides a parallel tie down point along each bed rail.
R,
HAP
Krab
Central Texas
This is a pretty useful and easy mod. I gotta do this on my next round of days off so I can secure my yeti to my bed. Thanks for posting this @HAP!
Palerider
What are the rings rated to? They would be perfect for hauling ATVs and dirt bikes
Krab
Central Texas
Ended up doing this mode over the weekend. Looks like the part number for the ring retainers has been superseded by 05170492AA for those interested. Only issue I had was getting one of the bed bolts loose. Ended up breaking two el cheapo T50 torx bits in the process. Great mod for little cost!
13Scott
SE PA
I just ordered 4 of these D rings and the dodge dealer I ordered them through said that part number is not good anymore so they found the superseded part that replaced that one but now the price is about $10 a ring.
HAP
HAP
NE NC
I just checked the other day and those rings are still available from the source in my original post for $3.44.
