Bed Light Rack/Bar Hoop Suggestions
richmeyer
Wisconsin
Who besides RPG is making the bed light rack/hoop? It appears Jimmy (WSI) is out of business.
Rear Light Bar Hoop - RPG Offroad
Check out SVC off road light tower, i have one build with manual actuator for the 50" bar.
Geo_Tactical has it too great set up.
Check out Addictive Desert design too.
When your bar is folded back, does anything stick up above the cab? I still need to fit into parking garages on occasion. Thanks!
SZDZMTR
Sewell, NJ
The tower itself is perfectly matched to the contour and the height of the cab. It almost reminds me of Turbo Supra with the spoiler blending in with the cab of the car itself when you look at it from behind. With the light bar folded back, its at perfect height, does not stick out and you can not even tell there is a bar by looking at the truck unless you look at it from the side. I think SVC nailed it 100%.
I did turn it backwards the other day and got wind whistle at 40 mph or above. It was turned facing 90 degrees backwards. I did not play with different angles but I think if I had it pointed down more I would have been ok, noise wise.
Good luck in your search. You can still have the bed cover if you wish, no problems with compromising space.
richmeyer
Wisconsin
Thanks!
Sent from my XT1585 using Tapatalk
---------- Post added at 12:51 PM ---------- Previous post was at 12:49 PM ----------
Can tab it up for whatever lights configuration you'd like as well as get lights for it. Can fab a rotating assembly if wanted too.
