MTGOAT
- Joined
- Apr 10, 2012
- Posts
- 69
- Reaction score
- 12
trying something new,
I bought one of Craven Speed's last bullet antennas the other day and put it on. I had to find a universal antenna kit and use one of the screws to mount in on the truck. It looks neat but I came up with the idea to mount the bullet antenna in a .50 shell.
I drilled out the bottom of the shell and took the short antenna from the universal kit and ran it through the middle. I am going to cut the antenna down, solder in the screw for the bullet antenna and solder a washer on the base of the antenna to keep it from moving around. Then I will simply screw the bullet antenna onto the threads inside the .50 shell and then screw it on to the truck.
Ill sand the brass down and hit it with some clear and mount it up. One thing I did notice is that the bullet antenna is a tad bit smaller then the .50 shell diameter. I would guess to say its more about .46 or so. I think if i add a little liquid electrical past around the inside it will seal it up nicely and it wont look bad after I roll it some. If i had an actual round that was fired rather then a blank i think it would look nicer. the blank has crimped ends that when I rounded them out it sort of looks beat up. it will work for a prototype though.
Once I find my soldering iron I will get this finished up and post some pictures for you to see. give me about a week, i may need to buy a new iron.
Update : Been working on this a little.
Notes are in the pictures.
