Weathertech floorliner
Batman
Byhalia, MS
I gotta get these. That looks like my Christmas present to myself. The guy that details my truck HATES the stock mats. He likes these also.
Batman
Byhalia, MS
I got some. I just have not installed mine yet. I am waiting to get my truck cleaned up and the old mats cleaned before I install the Weather Techs. They are a very nice liner thou. I have Husky Liners in my old truck and these blow those out of the water.
BOJANGLES
Chihuahuan Desert (EPTX)
Do you have the subwoofer??
If so, here is a crucial tip:
there will be a square cut you'll need to make in the rear liner to fit it around the subwoofer.
Trust me on this, when you look at the liner and go to make the cut, follow the square as shown but round off the upper right corner in an arch shape INSIDE the square.
So the cut on the left corner should be 90 degrees, while the cut on the right side should be more of a rounded off shape leaving some plastic within the cutout square left to cut later.
The reason you do it that way is so that you won't end up with a small piece of exposed carpet near the corner of the subwoofer nearest the passenger doors. If you leave enough plastic (even too much) you'll be able to cut it to exact fit with sharp scissors as you're installing it.
If someone reading this doesn't understand what I'm saying, you may have to look at the liner and then re-read this to get it.
shelteredraptor
on a rock
I sure am glad I got mine before the shit hit the fan weather wise around here, they work great! Thanks Birdman!!
