Tuffy lock box solution
Before I decided to install a console vault, I came up with this idea that has actually worked out pretty good, I also have the under seat box, which after installing wouldn't allow my hidden lock box to be easily accessed, by moving it to behind the rear passengers back seat it is actually quicker to access since it's just a quarter seat. I used a piece of angle iron 2x2x1/4, than welded a plate that was the same size as the holder for the lock box. I mounted it to the rear seat studs,most it's not going anywhere, by using 1/4 angle iron it's not going to be pried or bent. To access it, I added some para cord to the rear latch so all you have to do is pull the cord and the rear seat back will pop forward. I hid the part cord in plain sight by tucking it under the seat cover and around the head rest post, to the causal looker you won't even notice it, and if it's dark or your in a rush it just looks like part of the seat cover. When I first started on it, I had it secured by regular nuts that were cleaned than red Loctite was installed, since then I went and picked up some "security" nuts that were red Loctited. I know it's not 100%, but nothing is, but it held a spare G19 and mag for over a year and a half.
ETA, It would only load one picture per post.
