Rear Seat Release - New Product for GEN1 and GEN2
  • Start date
Uzzirider
PHX
Thanks for the info. The raised sheet metal might be great to hang a couple of straps. I'll take a look tomorrow
No prob. I'm sure you could find a way to get something mounted back there. I'm planning to dynamat that whole wall. it's crazy how much noise comes through that area when you take the rear seats out.
BuiltRight
Thanks again for the orders and support fellas! I'm working on a much bigger production run right now, so the last of the inventory issues will soon be gone.
Those of you looking for a better solution back there once the seat is down will like what I'm cooking up right now. I'll post a couple teasers once I've got something respectable to share.
Cheers.
Wilson
South Dakota
Cheers.
Run your product threw Freedom Motorsports - Truck & SUV Performance Parts & Accessory Experts this way you can line up how many you'll need. Do group buys make frf great and Rick smile.
WRCRaptor
Great Lakes
Installed the other day easy install but I still tried to break the factory spring on one. Great idea wish I had these at 5000 miles not at 100k would have made life a little easier.
AbnMP13
Mississippi
I had done the mod but decided to give this a shot. Just ordered a set.
NM156
So Cal
Installed a pair this past weekend, done in less than 20 mins. Makes opening the seat so much easier.
Great customer service.
jps1145
Tehachapi, CA
Genius! Just ordered two. They're out of stock at the moment but should have another run by 4/20. if you order now while out of stock, they'll ship them for $1.00 when they're back.
srs
Tomball, TX
There are a few wires, cable and motor for the rear window slider, but that is about it behind there. Not much mounting points, the back wall is the back wall to the cab, it's not double walled. So any screw you put through there will exit the cab. There a few "tabs" and a channel welded on that allow for clipping the back wall carpet in place. To mount my amps I used these to mount sheets of polypropylene as mounting locations for the amps.
