Novus Plastic Polish and Cleaner
R1jamn
Upon delivery of my '14 Raptor, I witnessed some scratches on the plexiglass the covers the gauge cluster.
Another forum member suggested a product called "Novus".
So I ordered Novus #1 (cleaner) and Novus #2 (polish for fine scratches).
The results were good. The product will definitely polish plastic.
The deep scratches did not come out though.
Novus does offer another product, Novus #3, that is for removing deep scratches.
I may need to order some of it and give it a try.
I applied Novus #2 a total of three times.
It was more of a liquid wax. Rub it on then let it dry to a haze, then polish it out.
NickPic83
Rockland County NY
Novus is pretty good. I have used it on my original plastic vert rear window on a 94 and it took out smaller scratches.
R1jamn
R1jamn
Do you think it would work on the nav screen?
If you have deep scratches I would use the whole Kit.......Novus #1 thru #3.
Make sure to test any product that you plan to use in a small section though.
Novus did brighten up the plexiglass that covered my gauges.
