I was trying to take out my drivers side vanity bulb when it popped while still in the housing. I said fck I'm never gonna get this thing out now. The next day as I was driving to work I tried to turn on the map like only to find out it wasn't working! When I opened the door the dome and map LED lights would come on which was weird. So I figured it was a blown fuse! If y'all don't know, the fuse panel for most of the electronics are located underneath the passenger kick panel (under the aux pass through wires). Fuse #4(10amp) is the the one u want to pull. Sure enough the fuse blew. Changed that up, needle nosed the hell out of the broken vanity bulb and BAM! We have lights again!
Just thought I would do this little write up for people who are having problems with bulbs, or don't know why the lights aren't working like they should. Should be as simple as changing the fuse... Sometimes.
