Fire extinguishers
aR4CE
Spring, TX
Search hasn't revealed any up to date fe mounting ideas. Any cool places out there?
Jimbo
Mad Frog Mattis
IL
Where do you want to mount it? There's seat mounts, others have made door mounts/console mounts, or chase rack mounts.
aR4CE
aR4CE
Spring, TX
I did see that one, thanks!
I'm going to be running everything from the MFT/LGE mount.. I'm hoping to mount the FE to seat bolts or something.... but google isn't much help.
Jimbo
Mad Frog Mattis
IL
Thanks- That's what I was looking for. I'm going to measure and see if it will fit behind the driver's seat
I had mine in front of the driver's seat. You could angle it closer to the floor or closer to the seat. Never got in the way of my legs either.
punchinpaper
I could just see a morning coffee filled adrenaline commute and a twitchy foot leading to never being able to get my truck interior clean again.
Deleted member 12951
If you are wanting to put it behind you, then mount it behind on the center console, that way either the driver or passenger can reach it. If you search, you will find quite a bit of locations inside the cab where folks have put them. I'll try and find mine and post it up.
