Dechromed the console
Houston Raptor
Finally got rid of the chrome on the shifter, surround, and cup holders. Pulling it apart was super simple, and used the same rustoleum "soft iron" as I used for the tailgate emblem.
How did you do the shifter??? Also I see you in spring, so am I. You in HARO???
aR4CE
aR4CE
Spring, TX
You bet- you'll know me by the hi lift jack for sale post on HARO. hit me up
This video was a big help in getting the shifter apart. Once you have it out of the truck, it's pretty straight-forward to take apart. (being careful with clips and prying and whatnot). Toughest part is unclipping the shifter console; i just took my time and used a long flat blade. I can help out too if need be
https://www.youtube.com/watch?v=Yx2pETbNhCY
Ajh15
Did you do anything to the plastic prior to painting? How is it holding up? Does the texture have a different feel? Thanks for the info!
aR4CE
aR4CE
Spring, TX
Scuffed it with high grit paper and hit it with some alcohol. Texture is a bit rougher but I didn't wet sand or clear coat. Shifter is holding up good- I might hit the over pieces again and possibly clear- metal cans can and stuff can chip it.
Houston Raptor
Oh yea, I saw that earlier today.
Thanks for the video, I recently changed out my door handles for the black ones as I wanted the chrome out of my truck. The shifter was the only thing I was worried about.
aR4CE
aR4CE
Spring, TX
I was thinking of doing the handles as well. Any tips or writeups? did you buy black ones?
Houston Raptor
I bought the black ones off eBay, $50. The handles are black, but the housing is more of a dark chocolate color, so I just took a rattle can to them and made them black.
RangerRob
Ramona, CA
Nice job! I did the same thing to my interior pieces about a year and a half ago. I've had to repaint the shifter pieces a few times because it seems to chip easily. I pulled my door handles apart and painted those as well, but now that you mentioned finding black handles on Ebay I may go that route instead.
-Rob
