c-ne-elk
Got tired of the shinny shifter and attacked it with the plasti dip yesterday. MUCH better look!
Did not / could not remove the shifter so just taped everything off and sprayed it. Down where the shifter meets the plastic guard at the bottom of the shifter, there ended up being a small gap of silver after stripping off the masking so took an artist brush and loaded it up with plasti dip to the point where it was wanting to drip off and carefully let it "drip" off the brush onto the chrome for several coats. Worked great! If you try to brush it on the plasti dip does not want to come off the brush but if you load up the brush and then just touch the surface and let the plasti dip run off the brush onto the surface it will come off the brush and on to the other surface.
