Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > GEN 1 (2010-2014) Ford SVT Raptor Forums > Ford Raptor Interior Modifications Forum [GEN 1]
Ambient lighting
This is a discussion on Ambient lighting within the Ford Raptor Interior Modifications Forum [GEN 1] forums, part of the GEN 1 (2010-2014) Ford SVT Raptor Forums category!
Sponsored By: Special Vehicle Concepts
Old 01-28-2018, 11:07 AM   #1 (permalink)
Chiefapple's Avatar
Default Ambient lighting
I知 planning on adding some ambient lights in he near future, and would like them on anytime the light sensor turns on the headlights. Anyone have a picture of the wore and where it is that I need to tap into? 2012 Screw.
I致e been searching for this information, but have only found some vague descriptions, unless I知 searching the wrong thing.
Chiefapple is offline   Reply With Quote
Old 01-28-2018, 07:18 PM   #2 (permalink)
Ironhorse07's Avatar
Maybe something in here, OEM (The Real Deal) Ambient Lighting discussion
I don't half-ass anything, I fuck it all the way up.
2014 Tuxedo Black Screw, 2017 Avalanche Screw
Ironhorse07 is offline   Reply With Quote
Old 01-28-2018, 08:43 PM   #3 (permalink)
Chiefapple's Avatar
That痴 definitely overkill for what I知 trying to accomplish. I知 looking to trigger a relay that will power the LEDS.
Old 01-29-2018, 03:24 PM   #4 (permalink)
Chiefapple's Avatar
Maybe nosbusa can help?
Old 03-06-2018, 08:20 PM   #5 (permalink)
Junior Member
Just piggy back off circuit for the clearance lights or corner bulbs. When they turn on your relay will activate....
Lowlife_raptor is offline   Reply With Quote
Old 05-26-2018, 09:40 PM   #6 (permalink)
Clay's Avatar
Junior Member
I might be a little late, but i just put in some ambient lights in mine. I found that the wire you want is grey with a green stripe, if i remember correctly. It is behind the fuse panel cover in a grey 10pin harness with only 7 wires in it. It plugs in just to the left of the sticker with your door keypad code. You値l need some needle nose pliers to get it out. The wire will be in a bundle wrapped in pink tap. You値l have to cut backchat back. I ended up cutting the wire and splicing them back together with the ambient hot wire and then grounded the ambient lights with a screw in the metal right there by the fuse box, but you can ground it however you want. I値l take some pictures later. Hope this helped and I知 not too late.
Also worth noting that this is the parking light wire so anytime your parking lights are on, the ambients will be too. So it works for auto but if you turn on the headlights or parking lights, it will turn the ambients on too.
Clay is offline   Reply With Quote
Old 05-26-2018, 09:45 PM   #7 (permalink)
Chiefapple's Avatar
Thanks. Got the solution a while ago, but I致e attached the pictures I received during the install that helped me tremendously.
Old 05-26-2018, 10:05 PM   #8 (permalink)
Clay's Avatar
Junior Member
Good to hear you got it. I could have used those pictures myself but i found someone who did it on the 150 forum that walked me though it. Now that i know how i may rewire it to the light sensor. Hopefully this thread can help someone else in the future.
Old 05-26-2018, 10:07 PM   #9 (permalink)
Chiefapple's Avatar
I pulled off of both. At this point I知 not changing it. The light sensor would have been a good idea also.
Ambient Lighting kit stevelp99 Ford Raptor Lighting Modifications Forum [GEN 1] 16 08-25-2017 03:08 PM
Ambient Lighting Question LittlEvil Ford Raptor Lighting Modifications Forum [GEN 1] 14 12-23-2014 05:41 AM
ambient lighting drj.raptor Ford Raptor Lighting Modifications Forum [GEN 1] 0 03-29-2014 09:07 PM
Ambient Lighting Question ericwestbygod Ford Raptor Interior Modifications Forum [GEN 1] 7 01-13-2014 11:34 PM
Ambient Lighting - Pre Order TheDoubleAA Ford SVT Raptor General Discussions [GEN 1] 53 08-04-2013 02:43 PM
