Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > GEN 1 (2010-2014) Ford SVT Raptor Forums > Ford Raptor Interior Modifications Forum [GEN 1]
2013-2014 Raptors Sync 2 -> Sync 3 Upgrade
This is a discussion on 2013-2014 Raptors Sync 2 -> Sync 3 Upgrade within the Ford Raptor Interior Modifications Forum [GEN 1] forums, part of the GEN 1 (2010-2014) Ford SVT Raptor Forums category!
Originally Posted by RC51TOFUMAN I will have to look for the email. Call Camera Source tell them you have a ...
Like Tree32Likes
Sponsored By: Special Vehicle Concepts
Old 07-04-2018, 11:50 AM   #61 (permalink)
Originally Posted by RC51TOFUMAN View Post
I will have to look for the email. Call Camera Source tell them you have a Sync2 and are going to upgrade to Sync3 utilizing the 4DTech company.
However you would like the front camera functionality. They would set you up with the equipment. They said it's pretty straight forward plug n play. But you would have to get their 360 degree unit.
If you really wanted to you could setup your truck for 360 degree camera view as well.
Let me know
Sent from my SM-G950U using Tapatalk
I'll call them later this week. I actually wouldn't mind having the 360 camera setup. Just wondering where the extra cameras would be mounted.
RC51TOFUMAN likes this.
My build thread: http://www.fordraptorforum.com/f65/w...6/#post1012544
Truckzor is offline   Reply With Quote
Old 07-06-2018, 11:54 AM   #62 (permalink)
Junior Member
Originally Posted by tock View Post
Question though for those that have done this...I'm assuming all 13-14 raptors have automatic climate control (or maybe just 802a's), but I have not been able to get the temperature change overlay to work. Everything else is fine, the hard climate controls and the touchscreen controls both work, but when changing the temperature I do not get the radial overlay similar to what you get when you change the volume. The temperature settings change on the screen, but are not visible when in carplay/android auto. Being too lazy to switch back to the sync display, i find myself cranking the temp all the way one way or another instead of just setting a temp and letting it do its thing.
Just a follow up to the climate change indicator issue. I loaded an APIM config from a 2017 Raptor to see if that would get me working, but it did not. In fact I lost all control of the climate from the touchscreen. I tried a few documented changes related to CCR and climate configuration, but eventually threw in the towel and restored my backup.
Seems it's not possible to get that working. There are a lot of nibbles in the APIM config that have unknown effects, and many of these are different between what I had and what I loaded from the gen 2 as-built. It's a lot easier for the 2015+ guys since other than the APIM the rest of their hardware is the same SYNC2 to SYNC3, and they can just load a full APIM config from a later, similarly equipped truck. Pre 2015 guys have to hack at it and just accept some things just won't work.
No luck on the camera either, but guys selling these kits for $2k+ say it won't work either so I'm somewhat inclined to believe that. There are workarounds using third party cameras and adapters, but I'm not about to mess with all that.
I hope someone can prove me wrong, but on the other hand I'm surprised it's possible at all to get (mostly) working SYNC3 in a truck that was built long before it was released.
tock is offline   Reply With Quote
Old 07-06-2018, 04:33 PM   #63 (permalink)
RC51TOFUMAN's Avatar
Truckzor keep us updated thanks in advance
Ordered 3/6/13
Scheduled 4/29/13
Updated Build Date 5/1/13
DELIVERED 5/16/13
RC51TOFUMAN is offline   Reply With Quote
Old 07-09-2018, 09:43 PM   #64 (permalink)
I actually spoke to someone at the Camera Source last Thursday and was told that they do not have a solution for this issue. I did not get the sense that the person I spoke to had a lot of experience with these systems so I was planning to reach out to try again.
Old 07-09-2018, 09:47 PM   #65 (permalink)
Junior Member
Just installed sync 3 in mine, absolutely love it. Wish the front camera would work, but oh well, so much better than what I had before!
Dr0wningless0n5 is offline   Reply With Quote
Old 07-09-2018, 10:00 PM   #66 (permalink)
Truckzor
Try reaching out to Tricia at camera Source. I spoke with her. Here is a copy of the email
Sent:*Wednesday, May 9, 2018 10:51:31 AM
To:*[email protected]
Subject:*Camera-Source info
*Hi Tyler,
I spoke with one of our engineers and here is what you would need to do*
to retain a front camera on your 2013 Raptor.
Multi-cam interface:*
https://camera-source.com/accessorie...dios-2130.html
and
Front camera:*
https://camera-source.com/automotive...amera-kit.html
The multi-cam interface will be plug and play with the SYNC 3 radio.*
You will swap your factory camera for our Raptor camera and run the*
harness to the multi-cam interface. The interface will power the camera*
and create the RCA connection for the front camera.
Take a look and please let me know if you have any questions.
Thanks,
Tricia
Camera-Source
888-844-9763 ext 1
Truckzor likes this.
Ordered 3/6/13
Scheduled 4/29/13
DELIVERED 5/16/13
Ipad to replace 2013 SYNC MFT? george16 Ford Raptor Audio/Video/Electronics Forum [GEN 1] 2 12-10-2015 06:23 AM
2014 Sync make Nav default start screen? FastEddie Ford Raptor Audio/Video/Electronics Forum [GEN 1] 0 07-19-2014 05:45 PM
2014 Raptor, Problem with SYNC Jeff Quinn Ford SVT Raptor General Discussions [GEN 1] 4 03-08-2014 09:22 PM
2013 Sync Dead - Replacing J0shM1lls Ford Raptor Problems and Questions Forum 16 01-25-2013 02:31 AM
Sync Upgrade incubus Ford Raptor Audio/Video/Electronics Forum [GEN 1] 1 04-23-2011 12:02 PM
